Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-21-2004, 01:19 PM
ChristopherBrown ChristopherBrown is offline
Unhappy 1998 Ford Contour(rough idle.stalls.help)
I have a 1998 Ford Contour 79005 miles 4 cyl.
8 months ago the car started idleing rough, check engine lite came on, soon thereafter the car would die at lites or in park and nuetral. Had the car diagnosed and fixed......#3 valve was burnt out $1000.00
Two weeks ago car was driving allright then all of the sudden car wouldn't get over 40 mph idleing rough dieing at lights. Changed fuel filter, no change changed all 4 plugs no change....but #3 plug was fouled. The car will run ok on runs but still idles rough and eventually dies. now check engine light stays on.
I have recieved advice from numerous people such as converter,loose hose,worn out hose,hole in hose.....
Please help
Thank you
Old 09-22-2004, 12:51 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Whats the code for the check engine light? My guess is a vacuum leak which would definetly cause the rough idling. Not to mention, youll be running lean which could cause your plug to foul. Start up the engine and pop open the hood and listen for any vacuum leaks. First i would take it to an autozone and get the code(s) pulled.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-23-2004, 06:55 AM
Lightbulb
Thank you
If it were a vaccum leak were would I look to find the leak. Nothing looks out of the ordinary?
Thanks again
Old 09-23-2004, 10:47 PM
Re: 1998 Ford Contour
Originally Posted by ChristopherBrown
Thank you
Thanks again
try checking underneath the throttle body and between the EGR where all the vacuum lines run.
"The CEG Nazi"
www.contour.org
Old 09-26-2004, 12:10 PM
taking it to autozone Tuesday to check codes.
Only whistling sound comes from belt assembly, probably normal?
battery light now goes off and on. Also when turning over engine, feels like engine is dragging for 1 to 2 seconds then starts thank you
Old 09-26-2004, 01:36 PM
if the battery light comes on, thats usually a sign of a bad alternator.
"The CEG Nazi"
www.contour.org
Old 09-26-2004, 02:55 PM
would that cause the problems I am having
thank you
Old 09-26-2004, 03:54 PM
it could.
"The CEG Nazi"
www.contour.org
