Old 09-10-2011, 12:19 PM
carjimost carjimost is offline
Newer engine in my 1995 blazer
Hi,
this past winter was crude and my engine block broke, so I've been looking for a used engine and so far I have found only a blazer 2001 and a blazer 2000 engine, so my question is if I can fit one of those two engines in my 1995 blazer, vin W?
Thanks
Old 09-10-2011, 03:31 PM
old_master's Avatar
Advisor/Moderator
Re: Newer engine in my 1995 blazer
The basic engine itself will bolt right in but, all of the sensors, fuel injection components, intake manifold, throttle body, air intake, distributor, ignition components, and possibly cylinder heads, etc etc will need to be transferred from the old engine to the new one. It's not difficult, but it is time consuming. Major changes were done to the 1996 and newer engines: to make the job simpler, look for a 1995 or older "W" engine from either S, T, L, M, C, K, or G body GM vehicle.
You have to know how it works,
to figure out why it doesn't.
1995 blazer engine mounts hybird23 Blazer 3 11-04-2011 05:45 PM
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 09:32 AM
1995 blazer - engine stalls, gauges and brakes act up jbreitbach Blazer 1 11-09-2003 12:25 AM
1995 Blazer service engine light on awbooth Blazer 10 10-16-2003 08:38 AM
How to check engine trouble codes on 1995 Blazer Schwa Blazer 3 07-14-2003 12:39 AM
