Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-03-2011, 01:32 PM
salesmantony salesmantony is offline
Red face 98 camry battery cable
Hi,
I recently replaced the battery post clamp end of my positive battery cable on my 98 camry.
The darn thing keeps coming loose, and coming completely off the battery while driving. Since this car is primarily used by my mechanically ignorant step daughter, this is a problem. I'm thinking of using some thread locker on the clamping bolt, but I'm open to suggestions.
98 camry V6 auto, 267,000 miles (mostly highway)
Old 09-03-2011, 03:00 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 98 camry battery cable
I would try to get a Toyota OEM clamp. It would cost a bit more, but would probably be worth the extra piece of mind IMHO since you said your daughter drives this car. If you do use the thread locker, only use the blue stuff. The red would need to be heated to remove the bolt/clamp. Heat/flame around a battery is a bad idea.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
salesmantony (09-16-2011)
Old 09-04-2011, 10:46 AM
somick's Avatar
somick somick is offline
The problem might be with the bad battery post. Try to wedge something between the post and a clamp and then tighten it up.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 09-04-2011, 02:36 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I don't think placing something in between the post and the clamp is a wise choice. There are too many amps on startup to make this a reliable and non-sparking system (hydrogen gas generated in the cells). Buy a new clamp if it doesn't work.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-04-2011, 05:57 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Originally Posted by salesmantony View Post
Hi,
What was wrong with the old clamp?
And, is the new clamp the size diameter as the old one?
There are now two different size terminals, most Japanese cars use the smaller size.
The larger clamp size will fit, but never get tight.
Not a good idea.
My neighbor tried this with his truck. Not sure what metal he used, but 6 months of 24volts later it had welded the cable to the batter, destroying them both.
Old 09-05-2011, 12:01 PM
Not a good idea.
The old (OEM) clamp would not tighten onto the (OEM) post. You could tighten it completely until it would tighten no more, but still pull the clamp off the post with your bare hands. The new clamp will tighten onto the post (fits right on the end of the cable properly), but works itself loose. Hence the threadlock thought.
I'm with you on the wedge idea. Big amps on startup can do damage to a lot of different metals. Might be an ok quick fix, but not for long term.
Old 09-05-2011, 03:55 PM
Moppie's Avatar
Master Connector
Sounds like the battery post may have been damaged.
Loosen the clamp right off, and use fine file, or course sand paper to smooth the terminal.
Be careful not to short it out!
Then put the clamp back on and tighten it, but do not over tighten it.
You shouldn't gave to tighten it beyond half way. If you do, then its the wrong size clamp.
The Following User Says Thank You to Moppie For This Useful Post:
Old 09-06-2011, 02:38 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I second Moppie, sounds like it's the wrong size cable post clamp. Once tightened, there should be between 1/8" and 1/4" gap between the clamp ends.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-07-2011, 04:40 PM
The Original clamp (that would not tighten), is the ORIGINAL manufacturer clamp, and it is the correct battery. Someone mentioned stretched clamp, and I think that is the probable cause for needing to replace that clamp.
The replacement clamp IS the correct size, it fits the post properly, but just works itself loose.
I've re-tightened the clamp and applied some medium strength (blue) threadlocker on the clamping bolt. I will let everyone know how it works.
Old 09-08-2011, 02:48 AM
Moppie's Avatar
Master Connector
When the clamp is tight, how much free thread is there left on the clamping bolt?
It should be about 5-10mm between each end of the clamp.
The clamp will only work loose if it's the wrong one, the battery terminal is damaged, or it's not done up tight enough.
Old 09-09-2011, 07:49 AM
jdmccright's Avatar
The RustBuster
Only other thing I can think of is the clamp is relaxing, or creeping, under the high heat conditions in the engine bay. Normally this shouldn't happen, but maybe it was made of an inferior alloy or just a bad batch.
Thanks for verifying the correct sizes.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
The Following User Says Thank You to jdmccright For This Useful Post:
Old 09-16-2011, 08:03 PM
It's been fine for about a month now, so I think the blue threadlocker did the trick. I'm also pretty sure the original problem was caused by the metal of the OEM clamp stretching.
Thanks guys for your input.
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
97 camry battery cable wakeman Camry/Camry Hybrid/Vista 6 08-01-2006 03:26 PM
99 GP battery cables pbarber Grand Prix 1 03-07-2004 04:33 PM
Replacing Battery Cable On A 1998 Dodge Caravan nurseshell Caravan | Voyager 2 12-06-2003 12:35 AM
Changing Battery Cables? l2ice rocketz '88 - '91 Civic | CRX | Wagon | Shuttlee 1 09-03-2003 01:37 AM
Tags
battery , cable , camry
