Old 09-02-2003, 09:24 PM
l2ice rocketz l2ice rocketz is offline
Send a message via AIM to l2ice rocketz
Changing Battery Cables?
I was opting for a better gauge of Battery Cable. Mine are from like 13 years ago, and seem to be deteriorating down to the wire. How hard is it to do yourself? If not by myself, then how much would it generally run you for?
Old 09-03-2003, 01:37 AM
BullShifter's Avatar
If you use Honda or replacement cables it will be simple. When you make your own, crimping connections & so on, its slightly more difficult but still simple IMO.
1. Disconnect negative battery terminal
2. Disconnect positive battery terminal
3 Remove bolts holding negative cable & disconnect from tranny
4. Install new cable as old one was removed
5. Disconnect the positive cable from the starter & main fuse box
6. Install new cable as old one was removed
Also a good idea to replace engine to frame ground strap - Taylor makes a sweet braided strap - keep in mind it is a ground strap & not a batter cable by any means.
A shop would charge 0.5hrs of labor + parts/tax to replace cables.
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
99 Jeep Grand Cherokee battery change issue. brutass Grand Cherokee | Grand Cherokee SRT8 3 01-27-2010 09:21 PM
Changing battery cables masphx Camaro Discussions 1 12-04-2005 12:36 AM
Battery light on, already changed battery and Alternator what could it be? TannerJac Malibu 4 07-31-2005 11:02 PM
How do I change the battery cable 1999 vifa84 Blazer 4 05-16-2005 05:43 PM
