Old 08-31-2011, 08:54 AM
mobby mobby is offline
Smile Lights wont go out
I have a 1995 S10 ZR2. The interior light will not go off when I close the doors. I have replaced the door switch buttons and still no help. is there some kind of control box for these or something. I have to remove the fuse just for light to go off inside. And no i havent left the light turned on at the headlight switch. But is it possible that the headlight switch could be the coulprit.
Thanks
Old 08-31-2011, 10:16 AM
Re: Lights wont go out
Just had a thought about this...Is there a switch of somekind for the light bulb under the hood? I see that there is no bulb in the socket. so maybe thats the issue? How does the light under the hood get activated?
Old 08-31-2011, 10:43 AM
blazee's Avatar
blazee blazee is offline
Problem?
A lot of times this is caused by the switches not getting fully pressed when the doors are closed. As they get older the doors sag or door panels may have moved or not been reinstalled properly after a speaker change... any of these can cause a misalignment. To eliminate this as the cause, I would start by getting a friend to help you. Each of you get a side and fully press the button by hand. If the light goes off, you've found the problem.
Old 08-31-2011, 11:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If that does not turn them off check head light switch dome light overide /switch.
Or optional dome light on/off switch.
Let us know how it goes.
MT
Old 08-31-2011, 11:54 AM
Ok, I tried holding the buttions manually, no luck. I changed them both out(cheap enough). I then unplugged the plug that plugs in the headlight swith and no help. Now im going to look at the glove box swith and see if that may affect anything. Tell me if im wrong but if i unlug all the switches and buttond then they sjould be off right? I really need this fixed because i cant use my horn with the fuse unplugged as they are same circuit.
Thanks
Old 08-31-2011, 01:53 PM
MT-2500's Avatar
AF - Advisor
Thanks
Glove box light has it own ground citcuit.
On dome light about 5 things can be grounding it out and /turning it on.
Interior lamp control module.
Did you give it time to time out?
Rear view mirrow lamp.
Keyless entry module.
Head light Dimmer switch
And door jam switches.
On tail gate did the dome light used to come on when tail gate up.
Another place to consider.
Remember it is grounding some place to turn it on.
Unplug all of the things that can turn it on.
If that does not kill it you have a wire grounded some place.
MT
Old 08-31-2011, 08:03 PM
Problem solved, it was passenger side door button switch wire was broken, hard to see but its fixed. I also have a bad 3rd brake light, man its all corroded and messed up. Anybody know where i can get a new one at?
Thanks
The Following User Says Thank You to mobby For This Useful Post:
blazee (09-01-2011)
Old 09-01-2011, 06:08 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back fix and how it went'
On the 3 brake light Dealer or bone yard.
Good luck
MT
2000 Blazer Back Up Light Wont Turn On? panteli2011 Blazer 3 01-23-2010 07:23 PM
Help! my third brake light wont come out SITNLOWVT '88 - '91 Civic | CRX | Wagon | Shuttlee 3 04-28-2005 11:26 AM
interior lights wont go out Billski Cherokee 1 03-12-2005 05:17 PM
service engine soon light wont go out 98NeoNDriv3r 1st Gen 95-99 2 09-12-2004 04:49 PM
ETS light wont go out? hdumas General Discussions 7 04-26-2004 08:47 PM
