Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-15-2003, 07:54 PM
hdumas hdumas is offline
ETS light wont go out?
I have a 1999 sufire co9nvert. The ETS light came on I can't get it to go back off. Does anyone have any ideas or has anyone had the same problem. Thanks
Old 07-15-2003, 09:42 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
There are many reasons for the ETS light to come on! Your best bet would be to take it to the shop and have them scan it. And go from there.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 08-19-2003, 12:31 AM
ve7fw ve7fw is offline
Check your owners manual. It says to tighten the gas cap.
Good Luck
Old 08-19-2003, 09:28 PM
Flatrater's Avatar
Main GM Guy
Re: ETS light wont go out?
Good Luck
What are you smoking in your pipe dude???
ETS means ENHANCED TRACTION SYSTEM it has nothing to do with the gas cap!!! A loose cap causes a SES light to come on you will not notice a difference in performance. And since you wrote this in another topic a loose gas cap will not cause your SES light to flash. A flashing SES light means you have a severe misfire that could damage the convertor!!
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 04-13-2004, 04:23 PM
beefbarley beefbarley is offline
Is the ets light on also with the check engine light ?I have had this happen and sometimes it was jut a matter of changing the spark plugs. One time it wass on it went off after I changeed my oil Crazy heh. I think it is best to have a diagnostig done on it . You may be able to prvent futher promblems that havent arisenyet . I have a 97 2.4 conv.I get my groceries fast as well a a nice tan
Old 04-13-2004, 04:29 PM
Re: Re: ETS light wont go out?
I have used fuel injector cleaner for a quick fix cant off hand remeber the brand name.But in case of a bad misfire ,need to check plugs , always they can tell you alot
Old 04-26-2004, 11:42 AM
tyrebob tyrebob is offline
It could be just as simple as a short in the thumb switch to turn ETS on and off on the shifter knob. I have a similar problem on my 95.
Old 04-26-2004, 08:47 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Man I hate OBD II systems... The problem is probably in a wire as sensors, even ABS brake sensors that take nothing but the wrost treatment from rain snow mud and salt, are pretty reliable thease days. If you take your car to an Auto Zone they will scan the ETS trouble codes for you and that will perhaps give you a starting point and save you money on expensive dealer labor.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
2000 Blazer Back Up Light Wont Turn On? panteli2011 Blazer 3 01-23-2010 07:23 PM
ETS Light OFF Check Engine Light On pryornfld Cavalier 5 01-24-2007 08:10 PM
ETS Light and Check Engine Light on moneeleann Grand AM 5 04-24-2005 07:33 PM
