Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-30-2011, 01:05 PM
rkvons's Avatar
rkvons rkvons is offline
Engine Oil Leak
Hi all,
I have this 1998 Monte Carlo LS with the 3.1. I just bought it recently and I've noticed that it has an oil leak. It's not the valve covers, and it doesn't really seem to be coming off of the top anywhere. I've looked around and can't seem to see where it is coming from. I asked the previous owner if he ever had the intake manifold gaskets replaced and he said no. So my question is really about the opening that used to be for the distributor. It has an o-ring in it that ends up getting hard and leaking. But would this cause oil to form drops on the bottom of the engine? This car has 181,000 miles on it. I know the oil pan is another possibility, but the fix for that is more than I care to do right now. Thanks.
Old 08-30-2011, 04:29 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Engine Oil Leak
If that o-ring is leaking, it can leak badly, could for sure cause drips on the botom end.
Old 08-30-2011, 08:28 PM
19k40rocky 19k40rocky is offline
Re: Engine Oil Leak
yup, GMtech1 is right. had the very same problem with my 3.4. Figured that out when I pulled the motor and had to replace the head gaskets as well. I think mine also was seeping out of one of the oil galleries coming up thru the block as well. but again that was a 3.4 and you got a 3.1
oil leak?????? freakyfire05 Accord/TSX/Accord Hybrid 11 02-22-2009 12:44 AM
engine oil leak Rick1331 Tercel 4 02-08-2006 09:33 PM
Engine Oil Leak kahuna123_2000 Caravan | Voyager 2 03-21-2005 10:46 AM
Engine oil leak under intake daddymart001 Grand AM 1 11-24-2003 05:22 AM
Engine Oil Leak patioman SC/SL/SW 3 05-31-2003 09:38 PM
