Old 08-28-2011, 12:59 PM
northstar1958 northstar1958 is offline
Bad injector?
97 park avenue 161,000 miles, developed a miss on cylinder 6. Pulled the plug and checked the wire, have spark on that cylinder. Disconnected the fuel injector wire on all cylinders, the only one that doesn't change in rpm is #6. Dirty injector? bad injector?
With the amount of miles i have, i'd like to pull them all and try and clean the injectors myself....just wondering if a DIY cleaning does any good. Anything else i should try before i attempt this? Thanks....
Old 08-28-2011, 01:03 PM
maxwedge maxwedge is offline
A990 racer
Re: Bad injector?
Check the injector resistance, 11.0.-12.5 ohms.
Old 08-28-2011, 04:09 PM
enslow enslow is offline
Re: Bad injector?
I've looked into DIY kits myself. I think the best kits use a combination of ultrasound and solvents, and operating the injectors. These kits are too pricey for a DIY, in my opinion. A good shop will clean the injectors and test them. I'd say that if an injector needs cleaning, that's money worth spending.
However, maxwedge's resistances check seems like a better place to start. I've never had to have injectors cleaned in one car with over 350000km and it runs fine and passes emissions tests. I'd suspect a mechanical failure of the injector before a dirty injector.
Old 08-28-2011, 05:00 PM
Re: Bad injector?
Checked the ohms....everything good.....It was the one cylinder i didn't check the plug itself....pulled it out...tested it...bad plug....I picked up 1 new plug (7013 champion platinum) and replaced it....runs like new. The plugs only have 30,000 miles on them...they are supposed to be good for 40-60,000 miles. I'm gonna replace them all...any suggestions on a good replacement?
northstar
Old 08-28-2011, 10:20 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Bad injector?
Iridium:
ACDELCO Part # 41101 Iridium
AUTOLITE Part # XP606 Xtreme Performance
NGK Part # 7164 {#TR55IX} Iridium
NGK Part # 5599 Premium Iridium
Copper:
NGK Part # 3951 {#TR55} V-Power
AUTOLITE Part # 606 Resistor
CHAMPION Part # 13{#RS14YC6} Copper Plus
Old 09-17-2011, 04:03 PM
Greg5150 Greg5150 is offline
Re: Bad injector?
Each injector has a micro basket filter in the top of the injector. It is a tiny filter. You can see what they look like in this picture: http://www.bonanza.com/listings/Fuel...Bosch/14317873
It only takes a small amount of debris to clog these and prevent an injector from working properly. These filters are pressed in and can be easily removed using a brass wood screw to pull them out. The new filter presses in easily.
I suspect bad injectors, but am open to other possibilities psychopathicdude Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 05-10-2005 01:30 PM
Bad Injector? Need Help JDM Motor 5gcivic JDM Motor & Parts info/chat 3 01-16-2005 10:29 PM
bad injector corey2225 Grand AM 15 01-05-2005 09:10 PM
96 monte bad injectors? audiopro Monte Carlo 1 12-10-2004 07:30 AM
Bad Injector? hexaine 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 05-29-2004 12:24 AM
