Old 12-09-2004, 12:04 PM
corey2225 corey2225 is offline
bad injector
how do you no when you have a bad fuel injector? becasue my car shakes real bad at idle and i replace sparkplugs,wires and fuelfilter.
Old 12-11-2004, 04:08 PM
lou S. lou S. is offline
Re: bad injector
Is your check engine light on? If so what are the codes?
Old 12-11-2004, 08:28 PM
Re: Re: bad injector
service engine soon light on which is the check engine light iam getting codes 300 and 303
Old 12-13-2004, 07:42 PM
Re: bad injector
It must be P0300=cylinder misfire detected(random), P0303=cylinder number 3 misfire. What year is this? How many miles you have on it? You may have to have the computer reset to clear the codes if you changed plugs because the computer will try to override the spark plug firingon its own. Its strange but that's how the thing works. My wifes 97 had a misfire on #4 so I changed plugs and wires and until I had the computer reset it still ran like s---. After resetting computer it runs great.
Old 12-14-2004, 09:35 AM
Re: Re: Re: bad injector
its a 2000 and the it has 95,000 miles on it and i took it to autozone and they erase the codes in it but they came back on.
Old 12-14-2004, 12:00 PM
Re: bad injector
OK. Did you try running some injector cleaner through?
Old 12-14-2004, 10:30 PM
yes twice still shaking bad i took it to the shop and they did a lot of test and couldnt find why they said that it was not getting enough fire.
Old 12-15-2004, 06:58 AM
Re: bad injector
I've read on other forums in here that the random miss is a tech's worst nightmare. What kind of plugs did you put in? Since the code states its cylinder #3 you may want to take a look at that plug. If you have the v-6 I know its a bitch to get at.
Old 12-15-2004, 11:17 AM
no i have the 4 cylinder i have ac delco 100,00 miles spark plugs came from dealer and i got the spark plug boots that go on them iam replacing the fuel pressure regulator now and i hope that work if you have any ideas please let me no
Old 12-15-2004, 11:28 AM
Re: bad injector
I am at a loss otherwise. If the plugs came pre-gapped make sure you check them just to be sure they were gapped right when the were manufactured.
Old 12-15-2004, 02:29 PM
Re: bad injector
fuel pressure regulator didint work
Old 12-15-2004, 03:13 PM
Re: bad injector
I am at a loss. If I read about anything or come across anything else that may help with the random miss code I'll pass it on otherwise it may be the injector (cylinder #3,P0303).
Old 01-05-2005, 09:53 AM
dsmall11 dsmall11 is offline
I just went trough this and it was the injector. I replaced coils, coil covern, fuel pressure regulater. it was my injector. You can move it to another one can the code should move as well.
Old 01-05-2005, 06:22 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Re: bad injector
While you are working on it, check the MAP sensor vacuum feed hose, for some reason mine was completly rotted, all other hoses were fine. Very odd due to the fact I have a '01 GA Quad 4, that hose should not be rotted yet. It caused severe idle problems and stalling.
Old 01-05-2005, 06:48 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: bad injector
The quick and easy way to narrow down either Coils or Injectors would be swap the Ignition Coils intead because that is very easy. If the misfire changes to another cylinder, then the Ignition Coil is the problem. If the misfire stays at the same cylinder, then the problem is with that injector.
