Old 08-25-2011, 11:15 AM
northerncountryboy northerncountryboy is offline
Exclamation Hard starting
I have a 97 blazer 4.3 and it cranks for at least 5 seconds before starting does this cold or hot. I have replaced the filter filter fuel pump and fuel pressure regulator, pump was changed about 6 months ago, all with delphi parts now is it possible the pump has a bad valve in it and it bleeding the pressure off, if i turn the key on and off 3 times let the pump cycle it starts right away. Any advice would be greatly appreciated.
Old 08-25-2011, 12:21 PM
NHRA's Avatar
NHRA NHRA is offline
Re: Hard starting
check the control module.....................
Old 08-25-2011, 03:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Hard starting
Originally Posted by northerncountryboy View Post
i have a 97 blazer 4.3 and it cranks for at least 5 seconds before starting does this cold or hot. I have replaced the filter filter fuel pump and fuel pressure regulator, pump was changed about 6 months ago, all with delphi parts now is it possible the pump has a bad valve in it and it bleeding the pressure off, if i turn the key on and off 3 times let the pump cycle it starts right away. Any advice would be greatly appreciated.
What are the fuel pressure readings?
Any codes or check engine lights?
MT
Old 08-25-2011, 09:56 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
Re: Hard starting
where is the control module located because im having a similar problem
Old 08-25-2011, 11:33 PM
NHRA's Avatar
Re: Hard starting
look for the coil its right beside it
some older modles are under the distribtor cap
Old 08-26-2011, 08:23 AM
Tech II Tech II is offline
Re: Hard starting
I agree.....put a fuel pressure gage on it...has to be above 60psi and not bleed down....
Old 08-31-2011, 04:26 PM
Re: Hard starting
Thanks everyone for the info i will check pressure this weekend and post readings and yes the check engine light is on but no scope, has been on since i bought it. and if fuel is good then replace module, i think this one is under the cap.
Old 08-31-2011, 05:13 PM
MT-2500's Avatar
AF - Advisor
Re: Hard starting
Also get code no and post back code no.
MT
Old 09-23-2011, 02:04 PM
Re: Hard starting
Ok sorry for not getting back on here right away but i figured out the problem, its the check valve in the fuel pump cause once i shut it off fuel pressure drops instantly to zero and i can hear it draining back. Service engine light is on beacuse of the check valve inside the tank. replaced the fuel pump cleared code and all is good, thanks all for the advice!!!!
Old 09-23-2011, 03:23 PM
MT-2500's Avatar
AF - Advisor
Re: Hard starting
Thanks for posting back fix and how it went.
We hope you used a Delhi pump.
If not you may be doing it again.
Check engine light and fuel pump/check valve are 2 seperate problems.
Outside of setting a engine lean code.
Did you check for codes and then clear codes and see if light comes back on?
MT
Old 09-24-2011, 08:47 AM
Re: Hard starting
Yes i used delphi pump, that was the brand that the check valve went out of so hopefully i dont have the same problem with the new one. Codes where clear and my buddy that works at a gm dealership said that the pressure dropping like that could show a vaccuum leak somewhere in the system. also said that egr levels were low and i started it once with out the mass air flow plugged in.
Old 09-24-2011, 12:44 PM
old_master's Avatar
Advisor/Moderator
Re: Hard starting
I agree with MT-2500: a leaking fuel pump check valve has absolutely nothing to do with the check engine light coming on. The PCM does not monitor fuel pressure or leakdown, so it can't set a code if there's a problem with it. Depending on what DTC you retrieved, it might have something to do with a vaccum leak, but not in the fuel delivery system. If the EGR readings are out of range, the PCM will set a DTC for it. No EGR DTC in memory.... there are no problems with EGR.
You have to know how it works,
to figure out why it doesn't.
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
