Old 08-23-2011, 01:17 PM
morjackson morjackson is offline
2001 Cav 2.2 engine shaking issue
Thank you for reading my post.
2001 Cav, 2.2 engine (Base model). 150K miles. Owned the car for 10 K miles. no problems up until now.
Starts fine but runs rough vibrates.
Computer code indicated injector issue on #1 cylinder. So I replaced injector and the spark plugs as well.
Plug for #1 was completely fouled. The others were okay, but a bit old.
No other codes were found.
I didn't check the plug wires or ignition coils. My thinking is a coil sending power to one cylinder should be sending to both. Then again, I could be mistaken.
I did not reset the computer as I don't know how to do that.
My plan for now is to check the plug wires. If they're still good, then I'll look at the packs. Any other suggestions are welcome and appreciated.
Thanks,
MJ
2001 Cav 2.2L engine problem Tim the 2Lman Cavalier Problem Diagnosis 1 08-02-2010 10:10 PM
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 07:21 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
2001 Cav 2.2 Engine SROBERT Cavalier Problem Diagnosis 7 10-11-2006 08:29 PM
