Old 08-06-2006, 07:07 PM
SROBERT SROBERT is offline
2001 Cav 2.2 Engine
I have a 2001 Cav 2.2 engine and have problems with starting the car.
Engine will turn over and act like its not geting any fuel, I can hear the fuel pump run for about 2 sec when key is turned on. I have tryed spraying starter fluid in air filter chamber and then tryed to start it and it would run only a few seconds.
After several attemps over and over I would get lucky and the car would start and act fine for a couple of days and then it would happen again.
Any Ideas?? Thanks
Old 08-11-2006, 11:17 PM
indyextremecustoms's Avatar
indyextremecustoms indyextremecustoms is offline
Banned
Re: 2001 Cav 2.2 Engine
just cause the pump turns on doesnt mean it is truely pumping the fuel properly.... test your pump and see how many PSI its runnig at... thnk it should be around 25 - 30 cant remember...
Old 08-12-2006, 07:56 PM
mstr3000 mstr3000 is offline
you could also try replacing the fuel filter. if you somehow got shotty fuel in there it is very likely that the ilter is clogged
Old 10-11-2006, 07:56 PM
Wigtail Wigtail is offline
Exclamation Re: 2001 Cav 2.2 Engine
Sounds just like a fuel pump problem. Mine has around 58 psi key on. I checked it today. Tricky though since there's no place on the engine fuel rail to check it. Had to check it at the fuel filter. My 5.7 350 chevy was doin the same thing. If it started it would run fine. If it wouldn't, i'd just squirt in a little fuel and away she'd go, till you shut her off. A new fuel pump did the trick. Watch out for those junk pumps on ebay. Been there, done that. Go to carquest and get a lifetime warranty. The whole module and all was less than just the pump anywhere else. Good luck.
Old 10-11-2006, 07:57 PM
Old 10-11-2006, 08:12 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Old 10-11-2006, 08:25 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Old 10-11-2006, 08:29 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
gee, what gave it away?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
