Old 08-23-2011, 12:00 AM
type0 type0 is offline
rear tire wear
hi i have a 2000 ford windstar lx i am having problem with my rear tire wear from the inside any help please?
Old 08-23-2011, 12:15 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: rear tire wear
I dont think the Windstar has any adjustment for 'toe in' or 'toe out' (which is what could cause this condition). I would check the rear suspension bushings for normal wear-and-tear. If there are bushings that look damaged, I would replace the bushing(s). If you bought the van used you should get a carfax report to see if it was in a collision prior to you purchasing the vehicle. Possibly...the rear struts are worn causing too much 'bouncy' motion, which would cause the tire's uneven wear. In any event, you need to physically inspect the rear control arms and bushings.
The Following User Says Thank You to Tony Silva For This Useful Post:
type0 (08-23-2011)
Tire wear overthehill10 Cars in General 1 05-21-2011 10:15 AM
olds 88 with uneven tire wear ryanusrey2012 Eighty Eight 1 05-09-2011 11:19 AM
510 irregular rear tire wear torp3do 510 0 10-14-2004 11:59 PM
Rear Tire wear please help! Flava888 Prelude 3 09-16-2004 02:28 PM
SL1 Rear Tires Wearing Out Quick jklutts SC/SL/SW 1 04-27-2004 12:18 AM
