Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-22-2011, 12:18 AM
tcseadoo tcseadoo is offline
No power to OBDII code reader
I have a 97 Rodeo 3.3L V6 and can't get the code reader to power up. I thought it was my reader so I bought a new one. Same problem, no power when I plug it into DLC. Used to work fine.
any ideas??
Thanks
Old 08-22-2011, 03:37 AM
snshddog snshddog is offline
Re: No power to OBDII code reader
Check pin 16 in the connector for battery power. It ties into the power the horn uses so check your horn fuse if there is no power.
The Following User Says Thank You to snshddog For This Useful Post:
tcseadoo (08-22-2011)
Old 08-22-2011, 11:35 AM
Thanks. The horn works fuse is fine. Any other ideas?
T C
Old 08-24-2011, 04:32 AM
pin 4 and 5 should be ground, and don't trust that the horn working means there is power at the connector, check pin 16 for power
Old 08-25-2011, 03:36 AM
There is no power at terminal #16 on dlc. How can I fix this?
Thank you.
T C
Old 08-25-2011, 05:56 AM
The easiest and fastest way is to cut the wire at the back of the terminal, just the one for pin 16, leaving enough to attach to, then add a wire to a power source, leaving the other side where you cut not connected to anything.. the other way is to pull the harness apart and find then repair the break in the wire.
tcseadoo (08-25-2011)
Old 08-25-2011, 06:28 AM
Thanks, Snshddog. I'll try the easy method and see if it works. Will post result.
T C
Old 08-25-2011, 06:50 AM
the wire should be green with a red stripe but don't quote me on that
Old 08-26-2011, 01:04 AM
Took your advice and now I have power to the DLC and will be able to read the codes on the OBDII reader once the self-testing cycle is complete. I mistakenly erased the codes when I plugged the reader in with my newly established 12 volt power.
Thanks again.
T C
OBDII code reader Christophe Salvain Venture 6 07-27-2006 10:46 AM
Best OBDII Code Reader? scabahorn Engineering/ Technical 3 11-25-2005 09:45 PM
Need Help With OBDII CODE READER uate1to Windstar 1 02-27-2005 07:43 AM
Need Help With OBDII CODE READER uate1to Sebring | Sebring Coupe | Convertible 0 02-27-2005 02:50 AM
