Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-21-2011, 01:08 PM
89crown 89crown is offline
changing fluid in the differential
Can the differential fuilds be change at home or do you have to take it to a dealership for service. The last time i had this done it cost me over $400.00. I've been online and what i seen that it seems almost as simple as changing your motor oil. They also change the transfer case oil too. It is a 2003 gmc sierria 3.5 z71 4x4. what I'm trying to find out is this something that i can do at home and save money rather than going to a dealership and spending that amount of money again. Thanks
Old 08-21-2011, 02:19 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: changing fluid in the differential
Yes. This can be done at home, not a very difficult process.
Old 08-24-2011, 08:41 AM
Z15's Avatar
Z15 Z15 is offline
Yes you can easily do it. Here this should give you some idea of what involved. Although this is a newer truck, the differential have not changed a whole lot. Change rear differential fluid
Mike
2010 GMC Sierra SLT E. Cab Z71 All Terrain
2009 Cadillac CTS4 3.6L AWD Performance Sedan
Old 08-24-2011, 03:47 PM
Thank you mike for that how to information it was very helpful How about the transfer case is that just as simple or a little more difficult process. Please adviced Thanks again
Old 08-24-2011, 04:15 PM
Z15's Avatar
Z15 Z15 is offline
TC is easier, has drain and fill plugs as does the front axle. But be advised if you have an a push button transfer case you need a special GM AUTOTRAC II Transfer Case fluid. No one else makes a substitute. If you have the manual shift transfer use a Dexron III Automatic Trans Fluid. DO NOT USE Dexron VI ATF.
Mike
Old 10-11-2011, 06:13 PM
als_sierra_2000 als_sierra_2000 is offline
I changed mine just the other day, there is a good video on youtube about how to use a plastic tube and electrical tape around the quart bottle to get the new t-case fluid in...I also pocked a hole in the plastic quart container after a while to let air in and get the fuild into t-case quicker..get two cans of the blue stuff from the dealer...it needs two.....
ATF: To Change or Not to Change z4teen Eldorado 1 07-09-2011 03:26 PM
Changing the fluid in the Differential masapell Silverado 4 09-08-2009 04:45 PM
Fluid change 1993 raNGER Differential Reg Saretsky Ranger | Courier 2 12-05-2006 10:37 PM
Changing out the differential fluid? THiNkr4x4 Trooper | SLX | Bighorn | Wizard 0 12-22-2004 07:07 PM
Changing Rear Axle/Differential Fluid jdugan C/K 3 05-30-2004 04:25 PM
