Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 07-09-2011, 12:13 PM
z4teen z4teen is offline
Exclamation ATF: To Change or Not to Change
Hello forum,
So I have a 1988 Eldorado Biarritz with 180xxx miles.
The car has been meticulously maintained since day one and has had no major problems, but I have a question.
Under normal driving, the transmission seems to shift "funny." Shifts, especially 1-2 and 2-3 gears, are a little rough and slow, especially under slow to moderate acceleration. Punch the gas, however, and the car shifts quickly. I have never noticed it slip, and all the gears seem to engage.
As far as I can tell, the ATF has not been changed in years, and definitely not in the last 30,000 miles. I'm wondering if it might be time, as I don't know if it's been changed since 100,000 miles anyway.
Could anyone tell me what, exactly, to look for on the dipstick and whether or not a change is necessary? What about a flush?
Thanks!
Old 07-09-2011, 03:26 PM
maxwedge maxwedge is offline
A990 racer
Re: ATF: To Change or Not to Change
Is the fluid clear and red? Tough question without an accurate history usually doing that will not cure a problem if the filter is restricted there are worn clutches. Only pulling the pan will give some idea.
The Following 2 Users Say Thank You to maxwedge For This Useful Post:
Moppie (07-09-2011), z4teen (07-10-2011)
The myth about changing and not changing transmission fluid manaswee Cherokee 29 04-27-2015 09:33 PM
engine reving high not changing gears kilmurray1 Grand Cherokee | Grand Cherokee SRT8 6 07-03-2007 11:03 AM
2001 Jimmy--Will not change from 2hi to 4hi/4lo crkuyke Jimmy 3 01-08-2005 10:11 PM
35mph-40mph not change 2-3 overdrive automatic-transaxle alex-sweden Trans Sport 1 10-07-2004 07:24 PM
Can not change location where air blows hondas C/K 0 05-05-2004 04:49 PM
Tags
automatic , change , fluid , flush , transmission
