Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-21-2011, 03:55 AM
4stevis 4stevis is offline
99 Silhouette shuts off if gas pedal is not depressed
My 99 Silhouette 3.4l just developed a new problem. In order to start the vehicle you have to press down on the gas pedal and keep your foot down or else it cuts off. A little history....I've been having an intermittent idle issue. Sometimes after the engine is at operating temp on a day when the outside air temp is >70F, when you come to a stop the engine rpm would ramp down as with a normal deceleration then the rpm's would spike to about 1100 rpm's then back down to idle rpm's then spike again about 3 or 4 times until the engine cuts off. Once the engine is restarted you would have to press the gas pedal to get between 12-1500 rpm's or else the oscillations would re-occur and the engine would quit again. I've replaced the Idle Air Control Motor, and thoroughly cleaned the intake air horn and flapper, I've replaced the PCV valve and ran the codes in the computer: The codes were a possible purge valve, or a possible vacuum leak. Im leaning toward believing a worsening vacuum leak is the problem. Anyone have any ideas???
Old 08-24-2011, 07:44 PM
Tech II Tech II is offline
Re: 99 Silhouette shuts off if gas pedal is not depressed
Leaning towards a vac leak....
Gas pedal went to the floor on its own! bagem788 Traverse 8 11-08-2017 06:08 PM
Rattle/Clanking noise when clutch pedal not depressed Boehlldozer Forester 2 07-17-2011 11:05 PM
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 02:25 AM
Explorer won't start unless gas pedal is depressed SlyFox2099 Explorer | Explorer Sport Trac 3 10-24-2007 10:06 AM
4runner moves when gas pedal is depressed forest_grump 4Runner/GX470 11 12-05-2004 07:56 PM
Tags
idle , problem
