Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-22-2007, 11:56 AM
SlyFox2099 SlyFox2099 is offline
Explorer won't start unless gas pedal is depressed
Hello, I am new to this forum, but I have been searching everywhere for answers and coming up empty. I have a 99 Explorer Sport that I just spent the whole weekend replacing the alternator, tension assembly and serpentine belt on. I thought this would remedy a problem I have been experiencing off and on for about a year now. Sometimes the vehicle will only start if i have the gas pedal depressed. It seems to start, idle for a short time then just die. I am at a loss for what it could be. I thought maybe spark plugs, but am not leaning towards something in the fuel system. Anyone have any good suggestions or advice?
Thanks in advance.
Old 10-22-2007, 03:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Explorer won't start unless gas pedal is depressed
More than likely either the fuel filter, fuel pump, or idle speed control motor
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-22-2007, 04:01 PM
powermaster powermaster is offline
Most likely idle air control valve, make sure you clean throttle body with throttle body cleaner not carburetor cleaner. Good Luck
Old 10-24-2007, 10:06 AM
I appreciate the direction. I have gotten the Throttle body cleaner and a new fuel filter. I will start there. Thanks.
