Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-19-2011, 10:04 AM
Jlong77 Jlong77 is offline
2001 steering shaft replacement help
Hi! Looking for some help on steps to replacing a steering shaft on a 2001 Olds Silhouette. I've tried googling, to no avail.
There is a ton of play in the steering, and it's been determined that the problem is being caused by the steering shaft UV joint. I will be getting the part from a local salvage yard, so am trying to figure out the steps involved in removing and replacing this (to make sure I have the right tools, time, etc).
TIA for any info you can give!
Old 08-19-2011, 05:07 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 steering shaft replacement help
If your talking the lower steering shaft (the one that connects to the steering gear), It's pretty much straight foreward. Access the upper and lower pinch bolts, seperate the shaft from the gear, then the column, remove shaft from under dash (you may have to get a little "persuasive" with the boot to pull out the shaft.
1997-2003 Grand Prix Intermediate Steering Shaft Replacement tblake Tips and Maintenance 2 04-13-2011 09:50 AM
Steering Wheel Replacement john3mo Lumina 2 08-25-2010 12:52 PM
2001 Yukon Steering belbers1 Yukon 3 07-20-2010 10:33 AM
Steering shaft replacement weo38 Silverado 3 03-28-2008 10:39 AM
Steering Pump Replacement Help cavasinj Alero 3 03-23-2005 08:26 AM
