Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 07-20-2010, 08:27 AM
belbers1 belbers1 is offline
2001 Yukon Steering
Hey guys,
I started to notice about a month ago that the steering wheel feels kind of clunky. Whenever I turn or go over a bump, I can hear and feel this weird clunky sound/ feel. I don't know if it would be the idler arm or what.
Thanks for all your help guys!
-Brandon
Old 07-20-2010, 09:44 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 2001 Yukon Steering
Does it sound like its coming from outside the vehicle or inside from the column itself.
Old 07-20-2010, 09:47 AM
I think it is from inside the column itself. I haven't heard it while outside the vehicle. I can feel it when I drive. It is pretty strong.
Old 07-20-2010, 10:33 AM
Airjer_'s Avatar
The first thing you can try is this.
Open the hood and look the the steering shaft on the drivers side. You should see a bolt about midway that connects the two shafts. Rotate the steering wheel until the head of the bolt is accessible. Remove the bolt (do not rotate the steering wheel with the two shafts seperated). You should be able to slide the shaft towards the fire wall. Run the shaft in and out a dozen times. Put them back together and test drive. If you still hear the noise there is a bearing on the end off the column that is bad. If the nois goes away or changes that the intermediate shaft is bad.
Tags
2001 , steering , wheel , yukon
