Old 08-23-2010, 11:24 AM
john3mo john3mo is offline
Steering Wheel Replacement
I have a 1997 Lumina and I need to replace the steering wheel (a drunk friend bent it and basically broke it ). Can anyone give me some advice on how to properly replace the steering wheel without deploying the airbag. Will disconnecting the battery ensure that the air bad will not deploy? Do I really need to rent a "steering wheel puller" that is mentioned in the Haynes manual proceedure? Thanks.
Old 08-23-2010, 12:01 PM
maxwedge maxwedge is offline
A990 racer
Re: Steering Wheel Replacement
Disconnecting the battery for 10 minutes disables the SIRS, care in handling is still required, you need a wheel puller and torx sockets too remove the air bag, this may not be a job for a " dyer".
Old 08-25-2010, 12:52 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Don't slide that airbag module around on the seat or anything once it's free...static discharge can deploy it.
Treat it like you were holding a claymore mine...gently, away from your body, facing away from you.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Tags
replacement , steering , wheel
