Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-17-2011, 05:47 PM
drazenv drazenv is offline
O2 replacement
Have a 97 buick century and couldn't get the sensor out due to location,does anyone know if this engine tilts forward when you remove the top engine mount bolts?
Old 08-18-2011, 08:05 AM
bozr's Avatar
bozr bozr is offline
Re: O2 replacement
Yes it does. After removing the strut mount bolts use a ratcheting strap connected to the engine lift hook to pull the engine forward an inch or two.
I love the smell of Stoichiometric in the morning.
The Following User Says Thank You to bozr For This Useful Post:
drazenv (08-18-2011)
Old 08-20-2011, 04:27 PM
Tech II Tech II is offline
Re: O2 replacement
There is a special tool that goes around the sensor and using a univeral and long extension, easy to get out......
The Following User Says Thank You to Tech II For This Useful Post:
drazenv (09-06-2011)
replacing heads, clean or replace injectors? mlh Econoline 1 08-11-2005 11:44 PM
Water pump replacement.. and upper brake light/bar/LED replacement vballfun Blazer 4 05-12-2005 09:49 AM
what should I replace when I replace timing belt? stanleyeye Camry/Camry Hybrid/Vista 2 11-21-2004 03:46 AM
1992 325I Air filter replacement and spark plug replacement rdog28 3 Series 4 07-13-2003 04:47 PM
Replacing clutch (GSR). What all hould I replace? Parts illustration inside Hybrid93Hatch Integra 1 03-07-2003 11:53 AM
