Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-20-2004, 12:23 PM
stanleyeye stanleyeye is offline
what should I replace when I replace timing belt?
water pump, oil pump, tension spring, some gaskets, ...
Can some one give me some advice?
many thanks
Old 11-20-2004, 07:35 PM
canadianbiz canadianbiz is offline
Re: what should I replace when I replace timing belt?
When you do the timing belt make sure to install new crank seals. I dont know what year car you have but mine is an 87 Camry. My backyard mechanic friend and I did a water pump change, replacing the timing belt at the same time. Now 3 months later, I have the crank seal leaking oil. Guess we should have changed the seal when we were in there. For a couple of bux and little extra work its well worth it.
Old 11-21-2004, 02:46 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Yes, I agree. While replacing the timing belt, it's recommended by Toyota that you replace the water pump as well. It would also be a wise idea to get at those seals while they're accessible.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
