Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-17-2011, 03:50 PM
eric1h eric1h is offline
Fitting 305's x4?
for those of you with wider tires, anyone have any trouble or have to do anything special to fit wider 305s on all four corners?
Will this even work?
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 08-18-2011, 12:50 AM
panozracing's Avatar
panozracing panozracing is offline
Re: Fitting 305's x4?
I have 305's front and 325 rears....front fit with trimming of plastic, less turning radius (install new wheel stops) and proper offset
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-18-2011, 07:42 AM
I think the offset on my wheels is ok. I run an 18x10.5 now with a 295 and had trim the fiberglass a bit as well, so I think I'll be ok... what size wheel stops did you you? where did you source?
Thanks
Old 08-18-2011, 06:53 PM
I run an 18x11 rim for the 305's with a 1/2" wheel spacer
I had my race shop machine aluminum spacers and install them while they were doing a set down on the car. The size needs to be measured just shy of the rim rubbing the brake strut bar.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-30-2011, 03:34 PM
Any pics of the clearances? I have the wheels/tires on the car and I THINK they will be ok.. pass side it fine, drivers front might need to be "clearanced" some though, how much rear wheel travel is there? I have about 2-2.5" until the tire would rub the rear fender(fiberglass body) if the rear moves higher than that it will def. hit
Old 08-30-2011, 07:46 PM
Both front tires tuck inside the fender when compressing (Drivers front has about 2" between tire and plastic fender edge and passenger front has about 1" clearance). The rear tires (drivers rear about 2.25" and passenger rear has about 3") when resting. I just added custom fender flares all around which make things less accurate. You should get a set they look sweet.
I found some old pics of the fenders.....I'll post some new ones with the sweet new fender flares.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-31-2011, 02:15 PM
thanks brian, post those "after" pics!!
Old 08-31-2011, 07:58 PM
Squerly's Avatar
Squerly Squerly is offline
Yeah, I'd like to see the car with those new flares too!
Squerly
Old 08-31-2011, 09:30 PM
OK...still have some fitment to do with the plastic gasket/trim but they are basically installed. To remove the hood you undo a screw (like the hood screws) and the flares go with the hood. I have not raced with them yet but soon enough..... These are easily reproduced and the fit was pretty good. I might not paint them...cant decide
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
The Following User Says Thank You to panozracing For This Useful Post:
PanozDuke (09-03-2011)
Old 09-05-2011, 10:45 AM
Cobrafang Cobrafang is offline
I have got 315x30/18 Hoosiers R6s on all for corners using the TSW Nurnburg 18x10.5 rims.
Looks and rides PHAT!!!!
Tom
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 09-05-2011, 12:56 PM
u need fender flares as well!
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 09-06-2011, 02:05 PM
Well the tires fit, and no rubbing! a CRAZY amount of grip! love it!
Ohh and even with manual steering rack, it wasn't too bad! although shoulders were a little sore on monday! :-D
Old 09-14-2011, 06:58 AM
CMPanoz CMPanoz is offline
Tom
Would you have the TSW part number? What is the back spacing off set?
Thanks
Panoz GTWC 2
Panoz GTWC 3
Panoz GTS
Old 09-15-2011, 10:01 AM
Thanks
TSW Nurburgring18X10.55-114.3 27GMF This equals a 27mm offset and a 5x4.5 bolt pattern.
DISCOUNT tires has them for 256 bucks.
http://www.discounttiredirect.com/di...=Car%2FMinivan
Not sure why the minivan is listed in the URL...but THESE would look awesome on the wifes honda odessy.
You do have to have the center hole machined to create the small wider part needed to fit the hub...but machine shop should have no problem.
GMF is gun metal finish...they have another finish on that size as well.
Racer and Gamer
Honda Fit or Kia Soul! Michelle.cobb Car Buying Q&A 8 05-29-2012 02:13 AM
Intake coolant fitting biggflintmi C/K 6 04-15-2011 05:45 PM
305's on HD factory wheels? twomorestrokes Silverado 6 08-03-2005 12:56 PM
95's ext cab 350 and 305's Nave Cars in General 1 02-28-2005 11:16 PM
Help Needed..How to calibrate for NITTO 305's Suprteck C/K 0 01-11-2004 11:39 PM
