Old 04-12-2011, 05:12 PM
biggflintmi's Avatar
biggflintmi biggflintmi is offline
Intake coolant fitting
I am replacing the intake gaskets on a 92 c1500 350. I have the intake out but the coolant fitting that goes into the back of the intake broke on me. It looks like metal but breaks like plastic. Any 1 have any tips to get it out of there. It broke off flush with the intake so i cant grip it with anything the only thing left are the threads. I tried hammering a big screwdriver in there and turning it but it didnt work. All i can think of now is to chisel it out and try not to mess up the threads. Any suggestions from ppl who have had this problem would be greatly appreciated.
Brains are funny, You shake them around and its like whoa whos driving this ship.
Old 04-12-2011, 07:51 PM
j cAT j cAT is offline
Re: Intake coolant fitting
common problem with these. using a hack saw blade , with no frame , cut into the fitting , then when you have a good cut almost thru from end to end use a screw driver and gently collapse the fitting ..then with needle nose pliers unscrew..
use teflon tape when installing a new fitting. cutting into the manifold threads slightly will not hurt it ..but usually cutting that much is not necessary.......
Old 04-12-2011, 07:58 PM
brcidd's Avatar
brcidd brcidd is offline
My local tool store sells a kit just for this- it has the big easy out, a pipe thread tap, and a new hose adapter- all for about $25. Works great.
Very, very common problem.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-12-2011, 11:49 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The original fittings were made from zinc, and end up corroding badly...two of them, one in front and one in back to serve the heater core. Dorman makes steel replacements if you want to stay OEM pipe connections...test them with a magnet to be sure they are steel. Others will find a plain hose fitting adapter, screw it into the manifold, cut the quick-connect ends of the hoses off, and band-clamp them. Either way works.
I would be careful hammering at the piece remaining because any big pieces that break off go into the manifold and may not get flushed out. As suggested, you can saw part way into the piece through the hole in two opposite places. Then tap a screwdriver at the midpoint between the cuts to make it collapse on itself. Once you get it out, flush it thouroughly with water to get rid of the shavings.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-14-2011, 12:01 AM
I ended up using a hacksaw blade and a screwdriver to chisel it out. I had to cut it in 3 spots to get it out. It was so corroded it looked like it was welded to it. Now i just have to get it all cleaned up so i can put it back on. .I didnt even tear up the threads and thats what i was worried about. Thanks for the tips.
Old 04-14-2011, 07:17 AM
I have a lot of experience removing fasteners and fittings that have corroded themselves in place...
very small to very large in size. using an easy out on a corroded pipe fitting will just expand the metal fitting an bind it up more...cuting the fitting and shrinking its dia you can then remove it...
when its safe to do so using a good torch properly adjusted and sized you can remove most hardware siezed up...
as with most threads like you have here a round pipe wire brush will clean up the debris/corroded mess then using pipe tape re install new part.... good luck !
Old 04-15-2011, 05:45 PM
My original plan was to heat it up but turns out my propane leaked all out so i went to plan B.
what is the small hose that carries coolant to the intake? discretegeek B-Series/Bravo/Bounty/Drifter 1 04-07-2010 12:58 AM
Brown sludgy coolant (oil in coolant?) wagslick Malibu 3 01-03-2010 08:29 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
Will a Si intake manifold fit on a DX? 90CRXZCSi '71-'87 Civic | CRX 5 03-07-2002 09:36 PM
My intake won't fit howard_w13 Engine 21 10-02-2001 03:11 PM
Tags
coolant , fitting , intake
