Old 08-12-2011, 11:54 PM
jamesmetairie jamesmetairie is offline
98 hgh brake light problem=-
the center high brake light has gone thru 3 blubs in one month .there,s 2 blubs in it. the one that,s on the drivers side does have some play in the socket. everything else works good. i understand it is activated by the brake pedal switch. any idea,s will be appreciated.
Old 08-15-2011, 12:39 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 98 hgh brake light problem=-
The only think I can think of is that is is loose and is being vibrated as you drive.
Old 08-28-2011, 05:07 PM
mystery continues=- just burnted out again. question = is it true the dealer sells some kind of repair kit for the brake light switch?
also would this work?? =- run a wire from each barke light on the back fender on up into the center high lights.
years ago i had center high on my old datsun 210,s installed . they were made for a trailer and worked perfect .
No Brake Lights or Hazard Lights acidcrashdburnd Eighty Eight 1 06-06-2011 10:41 AM
Problems with rear brake light and rear turn signal arfabe16 Neon | Plymouth Neon 0 03-08-2011 07:57 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
