Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 08-11-2011, 05:56 PM
janandkyle janandkyle is offline
Exclamation Coolant
Hi everyone i have just purchased an 01 for real cheap because it gets coolant in the oil, and has a leaking radiator. is there any way to tell if its coming from the intake gasket rather than the head gasket? the car runs great...im willing/able to tear down to intake gaskets for visual inspection and go on to the heads if necessary, just don't want to replace intake gasket only to find out i gotta replac'em again along with head gaskets, i also hate to pull both heads if only one is bad but i guess that cant be helped lol
thanks in advance
Kyle
2000 Chevy S10 2.2l 5spd
1993 Saturn sc2 1.9l dohc 5spd
Old 08-12-2011, 05:53 PM
danielsatur danielsatur is offline
Re: Coolant
I would consider www.steelseal.com ,see Google ''Youtube Auto steel seal''
Old 08-12-2011, 06:16 PM
Scrapper Scrapper is offline
AF Premium User
Re: Coolant
thanks in advance
Kyle
do a comp test on both heads and see witch one on the head gasket or ceacked head you'll no witch one after that and look at plugs see if wet by antifrezze also.
good luck........
Old 08-13-2011, 11:27 AM
Tech II Tech II is offline
Re: Coolant
Yeah, have seen them done all over again because it was also a head gasket.....
On these vehicles, if it is a head gasket, it's usually cylinder #1, on the rear head.....
I would get the engine warm......since engine seems to run fine, don't think a compression test will show you anything.....now safely remove the radiator cap, and do an overnight coolant pressure test(since that radiator is leaking, it will have to be replaced first)......then the next morning, remove the plugs and disable fuel and spark, and have someone crank over the vehicle.....especiallly watch number 1 cylinder for coolant.....
If it was me, and the rear head or gasket was leaking, I would still do the front one too...
Old 08-13-2011, 06:21 PM
Re: Coolant
Yeah, i checked compression when i first got it, all cyls were about the same so that told me nothing, i went ahead and ordered both head gaskets and the intake kit now the question is how much of a biotch its gonna be to get at the back one?? looks like rolling the engine forward at the very least!! Also i just got a new a/c condenser to install when the rad gets here, anyone know roughly how much oil i should put back in after i install it and vaccum the system? By the way thanks everyone for the replies!!
Old 10-10-2011, 09:51 PM
Re: Coolant
hi guys, quick follow up, changed lim gasket and all is well!
Old 10-11-2011, 08:59 AM
aleekat aleekat is offline
Re: Coolant
Sounds like snake oil. Have you personally ever used this stuff? I don't mean a friend of a friend who has a cousin who used it.
Brown sludgy coolant (oil in coolant?) wagslick Malibu 3 01-03-2010 08:29 PM
High Coolant Temp and Low Coolant Warning Lights flashing scott3689 SC/SL/SW 2 10-25-2007 08:28 AM
coolant cap hiss/coolant dribble from same sharky88 Cherokee 9 04-13-2004 10:14 AM
1996 beretta 3.1 oil in coolant & coolant in oil autojoe General Discussion 2 04-03-2004 11:44 PM
HELP ME!! Low Coolant light comes on, but plenty of coolant! lizabethbaker Camaro Discussions 3 12-01-2003 10:34 PM
