Old 08-08-2011, 03:56 PM
bigfartter bigfartter is offline
1998 cavalier transmission fluid capacity?
Anyone know the1998 cavalier transmission fluid capacity? I hit something and it knocked a hole in my transmission pan. I believe that all my fluid has leaked out
Old 08-08-2011, 09:13 PM
procaddytech procaddytech is offline
Re: 1998 cavalier transmission capacity?
•3T30 Transaxle (Bottom Pan Removal)
4.0 qts
•3T40 Transaxle (Overhaul)
7.0 qts
•3T40 Transaxle (Dry)
9.0 qts
•4T40E Transaxle (Bottom Pan Removal)
7.4 qts
•4T40E Transaxle (Complete Overhaul)
10.6 qts
•4T40E Transaxle (New Converter)
2.6 qts
Add fluid until it is at or just above the full mark with the car off. start the car and immediately check the fluid and add until you can see fluid on the bottom of the stick. Get in the car, press the brake and shift through all of the gear ranges. Put trans back in park and continue checking and adding fluid until it is between the cold and full hot marks. Drive around the block to heat up and circulate the fluid. Then top it off.
1998 Oldsmobile Achieva--TRANSMISSION WON'T SHIFT... rheji Achieva 2 05-08-2012 11:42 AM
1998 Caravan, transmission fluid comes out of dipstick tube miller5531 Caravan | Voyager 2 08-30-2010 11:58 AM
98 Transmission shifting issue zawillia Windstar 4 05-02-2010 02:21 PM
2002 Cavalier oil capacity chetc45 Non-Performance 9 03-04-2005 11:57 AM
1998 Cavalier clutch/transmission problem jmccreary Cavalier 1 05-19-2004 12:01 PM
