Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 08-06-2011, 03:41 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
Key stuck in the ignition
ok now i know im not the brightest person around, but for some odd reason my key wont release from the ignition in my 01 bravada. the battery is low because the car has been sitting for a few weeks, but that does not mean the key should be stuck! if anybody knows how i can get it out let me know asap. im not worried about somebody taking my car as it does not currently run and i do have an alarm system, i just dont like having my key stuck...any and all help and info is welcome
Old 08-06-2011, 06:47 PM
inafogg inafogg is offline
Re: Key stuck in the ignition
try push on the shifter,pull/push gently on the key(if worn)
spray a little wd in cylinder
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-06-2011, 11:02 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Also turn the steering wheel either direction gently while turning the keyswitch off & on to be sure the keyswitch is fully in the Off position.
Old 08-07-2011, 08:51 AM
procaddytech procaddytech is offline
If it is a floor shift flick the button that you push in to shift out of park with the shifter in park. Sometimes it will not release enough to close the park lock switch and will prevent the key from turning back to the off position to allow the key to come out. If that does not help, some further testing will need to be done. Do you have a 2-door with column shift, a 4-door with coloumn shift, or floor shift? The schematics are different for each.
The Following User Says Thank You to procaddytech For This Useful Post:
Chris Stewart (08-07-2011)
Old 08-07-2011, 05:15 PM
Allegretto's Avatar
thanks guys for all the help i finally got it out. i searched the forums and found a thread that spoke of this issue. i removed a little panel below the key hole and pushed a screwdriver up there and it came right out!
Old 08-07-2011, 06:08 PM
thanks for the fix but would you mined being more specific...
what did you acually push or can u paste a short cut to the thread.
thanks
Live For Today
Yesterday is gone,
Old 08-07-2011, 08:59 PM
Allegretto's Avatar
sure there is a little circular shaped screw cover right under the ignition switch. it dont look like its important at all and its easy to access. it dosent take much to remove it. after i removed the cover, i just pushed a flathead screwdriver up there. you will feel the part move its the only thing youll be able to touch. i lifted the tumbler and the key came right out with no problems
The Following 2 Users Say Thank You to Allegretto For This Useful Post:
Chris Stewart (08-08-2011), inafogg (08-07-2011)
'97 Bravada that won't start, stuck in park, key stuck in ignition. Dangerboy9705 Problem Diagnosis 11 08-03-2012 05:35 PM
1993 gmc jimmy key stuck wizard00 Jimmy 2 05-24-2011 04:09 PM
Key stuck in ignition--1999 6.8L v10 Too Many Old Cars Club Wagon 1 08-28-2010 07:56 PM
