Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-02-2011, 09:17 AM
dschmitta dschmitta is offline
Post caprice running horribly
hey,
I have a 1988 caprice classic brougham. It seems to have a few problems, don't know if relatd or not. always runs with a miss and low power. when slowing down to stop, shudders and will not downshift until almost at complete stop. shakes at idle. when going up through gears if i need to give it throttle, car shakes horribly until i manually use gears to downshift. also, fuel tank seems to hold alot of pressure and will also make a loud thumping noise, even when car is shut off! please help. Thank you
P.S. seems to run worse the hotter it gets
Old 08-02-2011, 10:02 AM
j cAT j cAT is offline
Re: caprice running horribly
Originally Posted by dschmitta View Post
hey,
what engine is engine is in this vehicle...? what is the idle RPM ? you got tools to work this ?
this may be vacuum leaks..check with a vacuum guage , the vacuum , when looking for leaks..under/at the carb/TBI you will find most vac line failures...carb cleaner over time eats at the rubber..also any carb operating devices could be leaking...
measure the plug wire resistance. remove the distributor cap and check for arcing ..
plug wire routing on vehicles this old is usually not correct..make sure these wires are routed so they do not get damaged from being too close to the heat of the manifolds...
EGR valve may be leaking/operating out of correct range this would mess up the fuel air ratios..
Old 08-02-2011, 10:09 AM
it is the 305 engine. i do think the idle is set up too high, i'm also having an issue with he engine running after shutting off. I do have tools, hopefully the ones I need. Thanks for info
Old 08-02-2011, 02:13 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
I have a 1988 caprice classic brougham. It seems to have a few problems, when going up through gears if i need to give it throttle, car shakes horribly until i manually use gears to downshift.
Your shifting problem is most likely a TV cable that is not adjusted properly. Do a search here for the adjustment procedure.
It sounds like you have other issues also, when was your last complete tune-up (plugs, wires, cap, rotor, fuel + air filter, timing checked)?
Start with the basic stuff first.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 08-02-2011, 08:55 PM
after you get the engine running properly then post back with any others issues you may still have...
the idle should be 650 rpm in drive vehicle stopped..
one componet that can cause too much fuel to get injested with this engine would be the cannister purge valve ..this multi hosed device can get internal rupture and then liquid gasoline will be directly dumped into the intake by way of the vapor purge hose...
the vacuum lines at the base of the carb should have not fuel in them.or smell very strongly of fuel..
runs horrible at about running temperature scott83 Ranger | Courier 10 12-24-2007 12:38 PM
My 95 Neon Is Running Horrible! hsma 1st Gen 95-99 1 02-10-2005 06:38 PM
Truck running horrible....why? HardcoreZ28 C/K 13 10-05-2004 08:07 PM
Engine runs horribly on acceleration after Crank sensor replacement acm73 Grand Cherokee | Grand Cherokee SRT8 3 05-14-2004 03:29 PM
engine sounds and runs horribly rough after head gaskets replaced bigdaddypsb Grand AM 6 03-07-2004 12:23 PM
