Old 08-01-2011, 11:41 PM
hidden1 hidden1 is offline
pressure test reading
Hi ,is 40 psi ok for a new fuel pump on a 91 grand voyager 3.3?
-with fuel pump regulator air line off its 49.Even checked before new filter-40.
Runs fine but not sure if regulator is why its low.-should be 45 .
Old 08-02-2011, 12:49 PM
rkvons's Avatar
rkvons rkvons is offline
Re: pressure test reading
It's probably ok. Doesn't the pressure go up if you give it gas?
Old 08-02-2011, 07:16 PM
pump just went out..doesnt even give that sound its pumping now(will check relay/etc)..
I think pump is defective but it made a knockin noise like- before it quit pumping.
-one other time it gave out and restarted after 40 min..now nothing.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
Oil Pressure gauge reads 0 Rain Angel Phox F-Body Problem Diagnosis 8 11-01-2008 09:18 PM
Oil Pressure Gauge reading High Travelle575 Bonneville 3 02-22-2008 08:12 PM
Lifters noise and oil pressure gauge reading mike1tb Camaro Discussions 5 03-21-2006 12:59 AM
check engine test readings.... schid Explorer | Explorer Sport Trac 1 08-10-2003 08:14 AM
