Old 08-01-2011, 08:59 PM
mason2010 mason2010 is offline
98 s-10 5 sp 160k clutch line keeps busting
i have a p8 s-10 5 sp with 160k miles on it last Sunday the clutch line blew i replaced it 2 days later same thing and today another new hose blew about 6in from the clutch slave cylinder i have tried looking for any extra heat that could cause a failure but no luck i am trying to figure out what is causing the extra pressure in the hose any help would be appreciated
Old 08-02-2011, 09:11 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 s-10 5 sp 160k clutch line keeps busting
New GM oem replacement line?
Is clutch hard to push or working normal?
Are you getting a good plug-in on clutch cyliner?
When it blowed was it extra hard to push?
Got any exhaust leaks or add on exhaust pipes?
MT
Old 08-02-2011, 09:57 AM
everything felt normal up till the time it blows
i have had someone say it might be the release bearing or a clutch cable but i am not aware of a cable to check i do have a leak in the exhaust but that did not seam to be the cause to me i noticed the leak when i did a head gasket job 3 months ago and just the problems started this week
Old 08-02-2011, 10:33 AM
MT-2500's Avatar
AF - Advisor
Did you use a new GM OEM clutch line to replace it?
If not do so.
If you have a exhaust fix it.
Heat from a leak can damage the plastic line.
Confirm the line is pluged in good to slay cylinder.
If not pluged in good the line will shut off hyd. fluid flow and cause extra high pressure on line.
Make sure pressure plate is not extra hard to push at all times.
If all else fails get a pressure gage on line and watch for extra high pressure.
MT
Old 08-05-2011, 02:16 AM
found a hole in forward exhaust pipe under the heat shield large enough to stick my thumb through going to replace that when i have the money and some one told me that the hose busting could be do to a bad throw out bearing or heat from the exhaust any 2 opinions out there
1 fix exhaust
2 pull tranny and check throw out + clutch
3 Both
any other thought are welcome
Old 08-05-2011, 06:53 AM
MT-2500's Avatar
AF - Advisor
1 fix exhaust
3 Both
Did you not read and or forget to answer my post no 4 ????????????
What kind of line did you use for repair??/////////??????????
Throw out bearing has nothing to do with slay cylinder pressure build up.
As to someone told you who was the someone??????
If you want to go down on the street corner or coffee shop you can find and get a lot of maybe's on repair infomation.
MT
Old 08-05-2011, 09:18 PM
bozr's Avatar
bozr bozr is offline
Broken motor mount.
I love the smell of Stoichiometric in the morning.
Old 09-03-2011, 11:19 PM
RedNeckerson RedNeckerson is offline
Originally Posted by bozr View Post
Broken motor mount.
I don't know. It would have to move quite a bit, wouldn't it? Well, I'm curious anyway.
Hey, I thought in stoichiometric combustion there WAS no smell?
95 s-10 ecm ign fuse keeps blowing, HELP!!! jjgierke5 Problem Diagnosis 3 08-23-2010 09:12 AM
'96 Passat TDI: fuel lines keep breaking gabrieljensen '93 - '96 0 03-21-2007 03:54 AM
88 4WD s-10 Blazer vacum lines scooter38 S-10 6 08-28-2006 08:04 PM
Clutch adjustment keeps moving quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-22-2004 10:50 AM
