88 Blazer -transfer case vacum lines
Need some help with vacum lines, 4wd want engage, there was no vacum line hooked up to the actuater under the battery, and 2 of the 3 vacum lines coming from the switch on transfer case arent hooked to anything, so where should theese be run to and where,
Re: 88 4WD s-10 Blazer vacum lines
does anyone know?
What engine?
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
4.3L Z, 4 speed auto tranny,
Wow..I can't find anything on the 'net. I'll hit Mitchell in the morning...
there s a section under FAQ 4.3 TBI vacum lines that shows
how replace them. from it it looks like one goes to the actuater and the other goes to the throttle body, i got it hooked up and the 4wd works but theres vacum to the actuater all the time while running, i thought it sucked vacuum only when you shift to 4wd, is this right or i got it wrong? |
My '99 w/ the actuator under the batt. only had vacuum while in 4WD..
