Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-01-2011, 02:53 AM
simboa simboa is offline
93 Corolla suddenly dies
Hey all-
I have a 93 corolla with ~140k on it. It's engine runs great....when it's running. The other day, I came out of the grocery store and it turned over fine but wouldn't start. I left it overnight and tried again in the morning. It started up just fine, but then after about 4 miles, it died. No sputtering, shuddering, or odd sounds. It just turned off and wouldn't start again.
I've tried several times with the same result. After sitting for a few hours, it'll start and run perfectly for a few miles and then die with no warning! Battery is good and I checked the fuel pump and it appears to be working fine. Doesn't seem to be overheating either.
The roads here are rough, so maybe a loose connection? If that's it, I haven't the fainest idea where to check...
Any thoughts? Thanks!
Old 08-01-2011, 08:58 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 93 Corolla suddenly dies
First thing I'd try would be the ignition coil.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-01-2011, 09:29 PM
I'll check (multimeter, right?) Wouldn't that cause the car to run rough, though?
Old 08-02-2011, 04:31 PM
Brian R.'s Avatar
Resident Chemist
Multimeter may not tell the story. Multimeters testing the resistance at 9 volts doesn't reproduce the operating conditions of 40K volts.
I would just replace it with one from Toyota. Other brands are unreliable. Coil doesn't give any particular symptoms necessarily. Hard to diagnose. However, it is a really common part to break and cause crappy running.
Old 08-03-2011, 06:54 PM
Just swapped it out- yep! Definitely the problem. Also have a small oil leak, but a small o-ring should fix the problem.
Thanks!
Sudden Dying grodrianst '71-'87 Civic | CRX 1 10-15-2005 02:46 AM
22re engine suddenly dies claym Pick-Up 5 10-13-2005 09:30 AM
Engine suddenly dies and doesn´t restart inmediatly MaNoC Accent | Verna 0 05-22-2005 09:59 PM
94 Jimmy GMC suddenly dies themindbender Jimmy 2 01-14-2005 01:52 PM
