Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 05-22-2005, 09:59 PM
MaNoC MaNoC is offline
Lightbulb Engine suddenly dies and doesn´t restart inmediatly
I've suffered this problem: (Now I've found the solution)
My '98 Accent was running and suddenly dies and doesn´t restart until 15 to 25min of waiting, or cooling maybe too. This happens two times or three a day or never in 2 days but the bug is still there. I've tried everything (spark plugs, wires, ignition module, ignition sensor, maf sensor, injection, etc) but the problem doesn't disapear. But after looking the post "Starting Trouble after lil rest" in this forum I've deceided to change the crankshaft position sensor "CKP" (it´s under the clutch release cylinder inserted in the engine). The problem really disapeared and now I'm enjoying again my accent. Just try it, it's not expensive to get the part (here in Argentina I bought it for u$s 45, the original one) and it is not too difficult to change, you need only a screwdriver and a workbench to remove first the radiator, then the clutch release cilynder assembly and finally the CKP using a screwdriver. I hope it helps to anyone that suffers the same or similar problem. Good luck!
