Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-31-2011, 05:13 PM
lc1500 lc1500 is offline
Rear right noise
For about a year now I have heard a heavy knock near the right rear strut when hitting small bumps on my 2001 Camry. I slid under and forund that when I pushed upwards a bit, a heavy knock (like a small hammer on the frame) would occur at he junction of the stabilizer bar and the stablizer bar link (the small bar that attaches to the strut.) When disconnecting the juction, the knock disappeared.
The issue seems to be the lower joint of the stabilizer link. You can feel the knock while holding the stabilizer or the link.
Can a bad lower stabilizer link cause such an noise?
Thanks for your help.
Old 07-31-2011, 07:48 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Rear right noise
Yes, it's possible the link is bad. The more common problem is bad inner bushings that are inboard of the stabilizer bar link. Make sure the movement/noise is cause by play in the link and not the inner bushing(s).
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 10:59 PM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
Rear right axle noise while turning... GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 11-24-2008 11:31 PM
Constant noise on rear right wheel GunsnRoses88 Odyssey 2 07-15-2005 03:18 PM
rear right suspension noise....??? preludeSiRt Prelude 1 11-28-2003 08:44 PM
