Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-31-2011, 02:19 PM
geovair66 geovair66 is offline
2000 Venture cooling fans
Can anyone tell me at what point the cooling fans are suppose to come on my 2000 Venture? Are both fans suppose to be on when the a/c is on? (I have one on!) When the temp gauge hit about the 3/4 mark one fan comes on. Are both fans suppose to come on at all times when called for or is it normal for just one to come on? Thanks!
Old 07-31-2011, 02:24 PM
lesterl's Avatar
lesterl lesterl is offline
Re: 2000 Venture cooling fans
One fan will come on with the AC, the other will come on when temp is around 235* or appx 3/4 guage.....
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 07-31-2011, 03:41 PM
One fan is specifically for the a/c and one is specifically to cool the engine?
Old 07-31-2011, 05:23 PM
lesterl's Avatar
not nescisarily, but the pcm should control both....
Old 08-01-2011, 06:31 PM
sverker sverker is offline
A friend came by tonight with his -00 and since I saw this question earlier I opened the hood and had a look at the fans. Temperature was at 90 degrees C according to ODB-II, AC was on and both fans were active.
Looking at the wiring diagram for the -00 it is theoretically possible for the PCM to activate only the left fan but not to only activate the right fan.
Old 08-01-2011, 07:10 PM
procaddytech procaddytech is offline
Both fans should run. For low speed operation the fans run in series. For high speed they run in parallel. If one fan is on, the other should be also. The PCM grounds the relays according to engine temp. and A/C operation. What side does not run? Left (driver) or right (passenger)?
Cooling Fan sensor.....please read! Baffled! diecast92 Engine and Transmission 10 07-31-2011 11:23 AM
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 09:03 PM
2000 Venture blower fan high does not work stu padas Venture 1 09-18-2009 10:12 AM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
