Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 07-31-2011, 03:02 AM
zkershn zkershn is offline
High idle problem.
I have a 1988 2.5L 4 cylinder engine. I disconnected the old air filter and installed a 10" disc filter in it's place, but now the idle went from around 1.2 rpms to 2.2 rpms. Is there a way to lower the idle or would it maybe be a vaccum leak problem? I should mention on start up it goes up to about 3 rpms then settles down to about 1.8, but the idle goes up to 2.2 when I start driving and stop at a stop light.
Old 08-08-2011, 01:59 PM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: High idle problem.
Could be a vacuum leak(EGR) or one of the sensors is having issues. Are there any error codes?
Old 08-11-2011, 09:23 AM
Tech II Tech II is offline
Did this all happen after the Change? Wasn't there a vac line going to valve in the air cleaner, to direct warmer exhaust air during a cold start? Plugged it?
2001 Pontiac Grand Am: high idle, high rpm shifting gustie07 Grand AM 16 01-17-2015 02:56 AM
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 11:46 AM
94 cutlass 3.1 high idle gc9150 Cutlass Series 0 06-21-2011 05:51 PM
High Idle with New IACV - E150 XLT leroge Econoline 0 01-15-2011 05:21 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
