Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Technical: How To... - FAQs
Technical: How To... - FAQs All How To's and Frequently Asked Questions.
Old 07-29-2011, 03:05 PM
tripod12133 tripod12133 is offline
Send a message via AIM to tripod12133
How to replace timing chain on 84 Z 305 ??
Its running rough a little, you can hear a miss in the exhaust pipe, and it will start, run for a sec, then die. All synptoms of a timing chain jumped a tooth.
How do you check this and,
How do you fix this? Do you have to take the whole front of the motor off to do it?
Old 10-23-2011, 03:07 AM
big dwag big dwag is offline
Re: How to replace timing chain on 84 Z 305 ??
Put a timing gun on it, u should be able to tell if its out of time.
Old 10-23-2011, 10:16 AM
Tech II Tech II is offline
I'd really be eliminating a misfire problem(could be HEI, plugs, wires, valve problem, vac problem, etc.), BEFORE I would be pulling the front cover off for a timing chain....
Old 10-23-2011, 11:04 AM
Scrapper Scrapper is offline
AF Premium User
you could get it on number 1 cyl the take cap off and see if rotor button is pointing to number 1 inside of cap to see if it jumped time also.
What extra parts needed to replace timing chain, 97 Grand Am GT 3.1? Which chain? skseattle Grand AM 1 05-29-2010 03:40 PM
89 GP 3.1 timing mark for replacing timing chain cadillaction Grand Prix 10 01-27-2009 11:18 PM
How difficult to replace timing chain -2.7? jsgold Intrepid 2 04-08-2005 11:17 PM
replace timing chain? seannc Cavalier 26 03-22-2005 06:00 PM
2.2L died,replaced timing chain, now no compression...suggestions? Neetman1 S-10 3 07-11-2004 09:48 AM
