Old 07-26-2011, 03:48 PM
rpg rpg is offline
PO 449 code
My wife drove my '07 Silverado last week and after fill up the Check Engine Light came on. Of course I immediately blamed her for the problem but using my scanner, I get a PO 449 code. (Evaporative Emmissions solenoid, etc.). The truck runs fine, still gets good mileage (5.3L V8) but the code won't stay cleared.
Is this a gas cap seal issue or is there something else that needs replacing?
thanks very much for your kind assistance.
RPG
Old 07-26-2011, 07:46 PM
procaddytech procaddytech is offline
Re: PO 449 code
You most likely have a bad Evap Canister Vent Solenoid Valve.
Old 07-27-2011, 02:16 PM
j cAT j cAT is offline
Re: PO 449 code
RPG
if you like to fill up the fuel tank then after a very short ride shutdown the vehicle in a hot area the gas will get into the vapor cannister then the purge vent testing will fail , causing your dtc 0449 or others in the vapor test by the pcm...
remove the cannister/vapor vent lines and look for black goo ..if found clean up all this and you may luck out..
in the summer heat best no fill up the tank too much..then park vehicle..
The Following User Says Thank You to j cAT For This Useful Post:
rpg (07-27-2011)
P0304 code, rough idle, better since code charlie3 Contour 5 07-05-2006 12:26 PM
ODB code 33 and code 44 david-b Eclipse Problem Diagnosis 1 02-12-2006 08:27 PM
code 10 1988 ford separator code AbbyFord F Series 1 12-19-2005 05:10 PM
airbag code B2292 & code 33 ? 2003 Taurus ejb22 Taurus | Taurus Wagon 2 12-13-2005 04:08 PM
95 Z Code same as 94 Z Code? GeneP S-10 4 12-13-2005 03:03 PM
