Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-21-2011, 07:48 PM
jgriner jgriner is offline
replaced the starter now engine wont stay running
so I bought a used starter from ebay.
I installed the starter today, now the new (to me) starter barly will crank the engine, but it will start.
New problem, when I give the truck gas, then let it go back to idle, it will die. How could replacing the starter cause this problem? what the heck did I do?
Thanks john
Old 07-22-2011, 07:56 AM
danielsatur danielsatur is offline
Re: replaced the starter now engine wont stay running
How old is your battery?
Are the connections tight?
1) Have both the battery + alternator load tested at your local Auto parts store.
You need a strong battery for the starter, ECU, BCM, Electric Fuel pump, and other control modules for todays Auto's.
Old 07-22-2011, 08:21 AM
the battery was fine before I swaped the starter, I did kinda short it out, during the swap, maybe I blew something internally in the battery?
Old 07-22-2011, 08:30 AM
Don't tell them about the short, let them run the test for results.
The warrenty might just cover the cost of a new battery.
Old 08-16-2011, 03:57 PM
angus10 angus10 is offline
This problem would be easy to fix. But without knowing what year the truck is , I aint gonna bother.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 08-28-2011, 10:12 PM
soupcan fs soupcan fs is offline
you disconected power for a while if you did the ecm lost memory and you need to run it for a while and it should get better then shut off and restart. bumper to bumper auto john
The Following User Says Thank You to soupcan fs For This Useful Post:
jgriner (02-02-2012)
Old 08-28-2011, 10:28 PM
thats what was causing the problem, I drove it to the end of the road, and poof it was all better, The next day I disconnected the battery again and it started dying again, until i drove it for a bit.....
ecm, is the computer right? does that mean my computer is compensating for some time of engine problem? if so where should i look?
Old 08-29-2011, 04:15 PM
no it will do that evry time you disconnect the battery so if you leave it connected and it works good after tthe computer goes through a learning phase youre good also if youre battery falls under 10 volts it can couse the same thing to happen.
jgriner (08-29-2011)
Only runs with key in the START position AMAMEK9 Eclipse Problem Diagnosis 6 03-12-2011 07:47 PM
98 malibu wont stay running and the gauges dont qork zee750s Malibu 0 02-16-2008 06:54 PM
battery end changed now wont stay running bugnut ML-Class | GL-Class 1 08-29-2007 04:18 PM
replaced headgasket, wont stay running. S13Slide Taurus | Taurus Wagon 8 02-27-2006 11:47 AM
Replaced the alternator, NOW IT WONT IDLE! FiXThIsCaR Lumina 14 08-30-2004 06:29 PM
