Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-21-2011, 06:59 PM
JLKINSER1970 JLKINSER1970 is offline
ABS Light with no code
My ABS light has been going on and off for about a week now. It comes on while I am driving and stays on but if I turn the car off and back on, it goes off but comes on again while I am driving. The ABS system has even activated a few times when I was stopping on dry pavement. I took it to a shop down the street and he put his ABS scanner on it and no codes were found. So he used another scanner and no codes showed up even though the light was on.
I replaced both front wheel bearings about 2 months ago and they came with new speed sensors.
Any ideas??
Old 07-22-2011, 11:03 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: ABS Light with no code
Check the connectors to the wheel sensors. It sounds like one is losing contact and triggering the light especially given the fact that you said it resets but comes on after driving.
Old 07-22-2011, 04:30 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I agree with GTP Dad,
You might also check the wiring to the connectors.
What year Bravada are we discussing?
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
ABS light and code on 99 windstar kahjdh Windstar 3 06-23-2006 08:50 AM
ABS light reset code thisisme Ram Pickup | Ram SRT10 1 04-16-2006 11:28 PM
ABS light, no codes found dpollard Jimmy 3 01-05-2006 12:36 AM
ABS light on Codes indicate a faulty valve, Pump or Control Unit????? Evan Evans - LNS General Discussion 6 12-11-2002 09:04 PM
