Front door Hinge
2007 4wd 2500HD Ext Cab
My front drivers door is sagging. I checked “AllData” but all I can find is the following statement: ”The door hinge pins and bushings are not replaceable. If the hinge pins or bushings are damaged, replace the door hinge as an assembly.” I am wondering if this is a job I can do myself. Anyone have a procedure for this? Hinges don’t appear to be welded but I’m not 100% sure. |
Re: Front door Hinge
You might want to check the dorman section @ your local auto parts store for parts.
A new hinge is probably $350, I have rebuilt hinges for a LincolnTown car, that were not suppose tobe rebuildable. It was a matter of cutting the pins off, and matching the bushings + pins, see http://www.dormanproducts.com part # 38437 Last edited by danielsatur; 07-22-2011 at 07:32 PM. |
| The Following User Says Thank You to danielsatur For This Useful Post: | ||
bigrockk (07-21-2011)
Had to go back a few years, see http://lincolnsonline.com/tech/00045.html
You might consider buying a used one from a junk yard, and practice rebuilding it. |
Thanks again. |
AllData is kind of a replication of the GM service manual. So what you're seeing is buy this part from the dealer.
Do a Goggle search for door hinge replacements. Many parts stores have them in stock. Best to you.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Thanks Stickman, I have found them at many places online; if I can’t find them locally I will order them up and give it a shot.
