Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-30-2002, 02:17 PM
Lownslow's Avatar
Lownslow Lownslow is offline
All finished door hinge how to Lambo Hinges....
Well my other original thread dissappeared but hers id the one with everything fdone i hope i cleared it up for you guys so that you can do lambo hinges.
The only toold used were
Brass tubing one big one small both should fit just right
nylon thread or a scriber
File coarse and medium
Needlenose pliers
super Glue or epoxy glue(dont use regular kit glue the hinges wont stick to it)
patience and talent.
heres the tool i used
heres the door after i sawed it off use the files to clean it up a bit
this is a revised hinge only for the Corvette but the stright piece should be long enough to support the whole door
here it is mounted to the body you will have to modify the interior and chassie to fit the hinge
this is how it should open when the door is attached make sure you clear the windshield pillars and the roofand that it opened straight
the door is attached(use super glue or epoxy on the door and on the hinge and make sure you dont glue the hinge shut)
hers how it should look from behind the door the panel will still fit over the hinge and hide most the opening mechanism. my friend glues the rod closer to the middle but it causes opening problems after the interior is assembled the last 90 deg bend is to keep the door from tilting sideways during opening
so how did i do?.......
Old 08-30-2002, 02:37 PM
flyonthewall's Avatar
Car Mod guy
Wow, that's excellent, so simple - great 'how to'.
Can't wait to try it out on something but don't know what???
I wonder, can it be modified so that the door swing outwards slightly at the same time, like on some import conversions???
rcmaxx rcmaxx is offline
I have'nt even gotten the normal doors yet!!!!!!!!! anyways, good job.....
Old 08-30-2002, 03:08 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
awsome how-to only thiing is i cant see how or where u connected the hinge to the body? think u can take a pic of it?
Rui
(modeling) = Click Here
Old 08-30-2002, 03:18 PM
JE123's Avatar
JE123 JE123 is offline
Awesome!!!
I'm going to try that on at least one of my models. What did you use for the hinge?
-Joshua
Old 08-30-2002, 03:20 PM
Lownslow's Avatar
the hinge has to be connected to the strongest point of the Body(in this case the frame that holds the fenders and windshield pillars
Old 08-30-2002, 03:39 PM
just one more thing what did u use and how did u make the actual hinge?
Rui
Old 08-30-2002, 04:02 PM
Lownslow's Avatar
Needlenose pliers, Brass tubing, and wire.
for the brass get the smallest yet stronget available(look at the pic) it should give you an idea of what size it should be.
i eyeballed the hinge so i dont have any measurements.
Old 08-30-2002, 04:38 PM
Jay! Jay! is offline
Horizontally Opposed
Very nice!
Geometry says 'yes.' It would be a matter of changing the angle at which the tube part of the hinge was mounted, thus changing the plane the door would move upon. Then there's the matter of making everything line back up...
Hierarchy of Subaru:
(Click to see mine!)
Old 08-30-2002, 05:23 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
wow, very nice job.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 08-30-2002, 05:28 PM
XR6 Martin's Avatar
XR6 Martin XR6 Martin is offline
Looks awesome! Congrats!
Err you may want to blur out that phone number in the background....
Old 08-30-2002, 05:37 PM
Lownslow's Avatar
i tried that and it does work but for this project i want them straight up
Why bother the line is disconnected
Old 08-30-2002, 07:30 PM
damn
2000 BMW 323IT
1954 Ford F100
Old 08-30-2002, 07:35 PM
Midnight Racer's Avatar
Originally posted by kicker1_solo
damn
(by the way great how to)
Old 04-24-2003, 06:15 PM
ChopinPorkChop's Avatar
ChopinPorkChop ChopinPorkChop is offline
Send a message via ICQ to ChopinPorkChop Send a message via AIM to ChopinPorkChop Send a message via Yahoo to ChopinPorkChop
yes yes but how? and wat is the string needed for, srre for bringin up old thred but can u explain
My Msn: [email protected]
Closed Thread
