Old 07-20-2011, 11:13 AM
MikeS144 MikeS144 is offline
94 cav overheating
So far I have replaced the radiator, water pump and t stat. Currently I'm running with no stat and it still will run to the middle mark and higher on the highway. It doesn't lose any coolant and the oil is clean. What am I missing?
94 Safari 203000 miles
94 metro 310000 miles
Old 07-20-2011, 12:48 PM
inafogg inafogg is offline
Re: 94 cav overheating
are the cooling fans working? will it acually overheat(red line)or is it just
going a little past 1/2 way.was the system clogged & you replaced rad,pump ect. make sure area in front rad condenser clean from leaves ?
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 07-21-2011, 07:29 AM
Yes, the fan is working and I have made sure the front is clear. It overheated (almost to the red) two weeks ago. I was on the interstate and was in some serious hills. I pulled the t stat and limped home with the temp staying in about the middle. It used to always run on the first mark. My next thought is a plugged heater core. Gonna bypass it today.
92 Cav. overheated replaced thermostat now dies for no reason gargamel34 Cavalier Problem Diagnosis 0 03-19-2007 08:38 AM
96 Cav overheating problem mistertee Cavalier 5 11-30-2005 10:35 PM
'94 Cav. overheating.. but no heat. sweetashes Cavalier Problem Diagnosis 4 11-29-2005 08:20 PM
00 Cav overheating Cavowner Cavalier Problem Diagnosis 2 09-04-2005 10:17 PM
96 cav overheating and no heat pin0183 Cavalier 3 11-12-2004 05:23 PM
