Old 11-27-2005, 11:23 PM
mistertee mistertee is offline
Post 96 Cav overheating problem
My daughter's 96 cav was leaking coolant at the lower hose. So being a good dad I replaced the hose. A mechanic replaced the thermostat in the spring when he replaced the engine.
It overheated right away so I replaced the thermo.
Now it overheats again. It seems that the coolant isn't moving. The radiator doesn't get hot, but the engine shows hot.
Next step is to replace the water pump.
Any other ideas? How do you get the coolant back into this car after draining the engine? Is there a science to that?
Old 11-28-2005, 12:31 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: 96 Cav overheating problem
Are you sure the sensor on the dash is reading correct? If the radiator isnt hot usually it shudnt show the engine temp as hot, i feel my rad at like half way temp gauge and its hot/warm
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 11-29-2005, 07:24 AM
PatrickW22 PatrickW22 is offline
i think theres a sensor in the actualy radiator itself that lets the coolant go when needed, try that
Old 11-29-2005, 02:33 PM
cdru's Avatar
cdru cdru is offline
Re: Re: 96 Cav overheating problem
Nope. There is just the thermostat. When the engine is cool, it's closed and coolant just cycles through the engine, heater core, and back to the pump. When it warms up to 195 degrees IIRC, it starts to open allowing coolant to flow through the radiator.
If your car says it's overheating but the radiator and hose remain cool, you either have a blocked hose, airlock, faulty thermostat, or a faulty sensor.
Vinyl adds horsepower, right?
Old 11-30-2005, 08:23 AM
Re: Re: Re: 96 Cav overheating problem
I'm changing the water pump today. I think its an airlock problem. The heater gets hot then cold. So, the water is not circulating throught the system. I already changed the thermostat with no change.
Old 11-30-2005, 10:35 PM
Re: Re: Re: Re: 96 Cav overheating problem
Changed the WP today. It still started to overheat. I kept working with it to get all the air out of the system. Finally did and it works fine.
That was the problem.. Thanks for everyone's comments!
