Old 07-19-2011, 09:43 AM
Cojacks Cojacks is offline
Lightbulb Canadian 95 Civic Cx D15b7 to D16y8 Swap
Hello
My name is Corey and i have decided to make a thread about converting my old d15b7 to a d16y8 vtec.
So far i`ve come across two ways of doing the swap.
1.) Use Stock Harness and Ecu(obd1) by using
D15b7 Distributor
D15B7 Intake manifold with Injectors
D15B7 Exhaust manifold with stock o2 sensor
This will keep the system obd1 according to what i`ve read the internet
D15b7 Motor Mounts
D15B7 Alternator
D15b7 Clutch and Transmission
PLUS a Vtec Controller
2.) Use d16y8 Harness and Ecu(obd2)
Use all stock parts from the d16y8 motor
D15B7 Motor Mounts
Wire in 02 sensor
If anyone has done the swap i would appreciate any input
Thanks
Corey
ps-This is just some basic information
Old 07-19-2011, 11:24 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Canadian 95 Civic Cx D15b7 to D16y8 Swap
You can't use the D16Y8 harness, it too different. The '92-'95 Civics have a 2-piece harness; one piece is from the engine to the passenger side shock tower, and the second piece is from that connection to the ECU/under dash connectors. The '96-'00 Civics have a 1-piece, that runs from the engine straight to the ECU/under dash connectors.
Your best bet would be to do the #1 option, but with a different intake manifold and different ECU. The D16Y8 intake manifold is way better than the D15B7 one. In fact, it's the best OEM D-series intake manifold.
As for the ECU, you should either 1) get an ECU for the '92-'95 EX/Si (labeled P28). Or, 2) get an OBD1 to OBD2 (A or B depending on the exact year of the ECU) conversion harness, and get the '96-'00 Civic EX ECU (labeled P2P). I'd recommend the P28 route, since it will look for less sensors (including one less O2 sensor), and you won't have to worry about getting a conversion harness for the ECU, it will plug right in to your stock wiring. Both of these options would require you to run the wires for VTEC, to the ECU.
Using the stock 1.5L ECU and using a VTEC controller, is a horrible idea. Using anything to simply activate VTEC isn't enough, it's not going to provide the proper fuel and ignition timing maps. It would never run completely right, and you'd be losing power, all while effectively making VTEC engagement pointless. If you really want to keep the stock ECU, you could send it out to get a programmable chip installed in it, and just run a stock P2P (D16Y8) basemap on it.
Old 07-19-2011, 01:23 PM
Thanks for the quick reply
Going to get the ECU for the '92-'95 EX/Si (labeled P28)(obd1) because it plugs into my stock harness(obd1), makes the project a little simpler.
I'm guessing that all p28 ecu are Vtec
So far so good
Corey
Old 08-23-2011, 01:47 AM
Question !
Does anyone know if the cx distributor will fit on the d16y8.
(Checked on ebay and said they are no compadable)
The car is out of town or i would check myself.
Also i bought the p28 euc and have read that the ignition timing
is different but said it will still run!
Any input would be great.
Thanks
Old 08-23-2011, 03:34 AM
metalented metalented is offline
Guy..just a suggestion...Why don't you tried stamping simulation.
Sheet metal forming
By proccess of Hydro forming Simulation.
Old 10-02-2011, 01:21 AM
Read on the internet that the stock d15b7 dizzy will work on the d16y8.
Need some pointers on wiring up the vtek. Is there some sort of adapter
i can buy ?
thanks
Corey
Old 05-10-2012, 11:59 AM
Hello,
Quick nooby question.
Do you know how to get the to the ecu ?
I know it's behind the glove box someplace just havan't
figured it out yet.
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 08:48 PM
FS: 98/99 Civic EX D16Y8 Swap derekryans Classifieds 1 11-30-2007 11:19 PM
93 civic lx --> d16y8 swap jaeh '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 09-04-2006 01:26 AM
HELP---93 civic lx d16y8 swap jaeh '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-10-2006 07:46 PM
D16y8 swap in '92 civic cx hbk? odellcivic JDM Motor & Parts info/chat 9 06-30-2005 01:41 PM
