Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 07-18-2011, 07:08 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
91 Camaro rs Timing
91 RS with a 3100. Car came into the shop no start. Owner replaced the distributor, I got it running, unplug the timing bypass wire, line timeing up to 10 degrees BTDC, plug the bypass wire back in, and it wont start or stay running without feathering the throttle. Come to find out the computer is retarding the timing. Bypass wire unplugged and you can drive the car around the block fine, plugged in and it wont run. I need help on this one. The owner attempted to fix it himself before bringing it to the shop. He has a used pcm on the floor I swapped out, no change. I'm wondering if he has the wrong prom chip in it. Any suggestions?? I'm at my wits end on this one. I hate when people attempt to fix things on their own before bringing it in.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-19-2011, 11:10 AM
jdl jdl is offline
Re: 91 Camaro rs Timing
I'm a liberal shadetree mechanic,but that is another story. lol
It's my understanding, if the bypass wire has voltage on it and white wire has nothing, it won't run. With bypass ignition, it can run off the ignition module, but no spark advance without pcm control.
The signal on the bypass wire, tells the ignition module to use the signal on the white wire for spark timing.
3.4L 1993 Camaro timing problems hellfirea18 Camaro Discussions 1 06-22-2005 11:26 PM
Camaro VS Camaro VS slowstang SMOKEY818 Camaro Discussions 3 08-16-2004 12:59 AM
1996/1997 Camaro SS or 1998-2002 camaro SS????? chevynutss Camaro Discussions 39 07-18-2004 11:38 AM
1967 camaro 427 SS or a 2002 camaro SS dapriceiswrongb Car Comparisons 4 06-26-2003 11:40 PM
