Go Back   Automotive Forums Car Chat > Pontiac > Pontiac Classics
Old 07-18-2011, 01:13 AM
j4gwig j4gwig is offline
fuel problem with my 76 grand prix need help
I have a 1976 Grand Prix,,455 automatic,with a 650 holley carb.car runs great at idle and even if you stump on the gas,but if you run it up to 3 grand and hold it there,it acts like its running out of fuel,and it stumbles on take off,have changed pump and filter,has a clear filter and it stays full of fuel,while the car is acting up,,any idea's would be great..maybe its not fuel,I just dont know at this point,,, changed plugs,has tayler wires I dont think they would be bad,,car set for 10 years,before I got it...had the carb cleaned,with new acc. pump and power valve..
Old 07-18-2011, 01:22 AM
Re: fuel problem with my 76 grand prix need help
oh yeah how the hell do I get the distributor lose cant get it to move either way...
Old 06-16-2013, 10:14 AM
GTOHunter GTOHunter is offline
Send a message via Yahoo to GTOHunter
There's a vacccum advance that extends out from the lower part of the Distributor....check it and see it that's where Your problem lies?
Ok....the distributor is bolted/locked down with a forked shaped piece of metal that has a 1/2 inch or 9/16 bolt,it's located right at the base of the distributor shaft and is a PIA to get to.They actually make a funky little tool to loosen the bolt,it's a 2 piece tool that's L-shaped on both ends and it comes apart,it has a 1/2 socket opening on one end and the 9/16 on the other depending on the bolt size You need to loosen.
On a side note...You may need to spray a little WD-40 to loosen the bolt for the distributor hold down and don't over loosen it because the distributor with be able to spin or move too much or too easily.
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
2001 pontiac grand prix... need help with power doors vinniedee Grand Prix 10 07-07-2006 07:15 PM
2001 pontiac grand prix... need help with winshield washer vinniedee Grand Prix 6 06-06-2006 07:11 PM
