Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-17-2011, 07:07 PM
jamack1 jamack1 is offline
Engine replacement 2000 Regal GS 3800SC
Considering replacing the 3800sc in my 2000 regal GS. Can the motor be taken out from above, or does it have to come out the bottom with the drivetrain?
Old 07-18-2011, 10:12 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Engine replacement 2000 Regal GS 3800SC
The ideal way is to remove it from the bottom. It may be possible to remove it from the top if you remove all the accessories, exhaust manifolds and disconnect the flex plate from the transmission. This should give you enough clearance to remove it from the top. Just don't forget to support the transmission so that it doesn't drop down and bind the engine in place.
2001 3.1 engine replacement morjackson Lumina 4 06-24-2011 04:34 AM
98 Camry engine replacement. posiman Camry/Camry Hybrid/Vista 6 02-01-2010 01:00 AM
Replacing my '98 regal engine. Is this a good rate and engine price? bchalker Regal 1 08-25-2009 07:05 PM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
replacing cracked mirror glass only for side of 2000 regal 412BBB Regal 2 04-03-2005 07:36 PM
